RzeroB
As far as which automatic transmission to use, I was always under the impression that if you had a hi-po motor in your Mopar you needed to have a 727 behind it. However, I have seen quite a few race cars equipped with the 904. So why do some racers go with the 904 when the 727 is generally considered to be the stronger transmission? Is it because the 904 is lighter? Has less rotating mass? Better torque multiplication? Please, school me on the merits of using the 904 in a hi-po or race application vs going with the 727. Thanks!
