djsling
Anyone use the 63-66 v-8 Schumacher motor mount kits? How are they? For $144 gor brackets, insulators and hardware it's cheaper than buying used brackets I have found then gathering all the other components
They aren't just a repop of the original? 63-66 had one k member so not a conversion just v-8 bracketsThey're a high-quality product and work well. They do place the engine close to the firewall, so the distributor on a small block almost hits the firewall, and there's no way you're going to be able to keep the heater box. Other FABO guys have fabbed up their own mounts, placing the engine farther forward, and kept the heater box:
Engine swap 62 Valiant
So 63-66 you did? Did you have an firewall clearance issue as Bill mentioned? I don't understand how that could happen as same trans mountI have a set of the slant 6 to la! They are great. Best quality and best customer service. I messed up on my order and called to try and fix it. And Mike himself answered the phone and fixed it immediately he was super nice and understanding. Truly amazing company! Cant say enough good things about them.
I was also wondering how the Slant 6 to V8 conversion motor mounts worked on 67+ A bodies.
Do TTI and Doug's headed work with them?
I have them on my D/Dart. It has a 360 crate engine in it. Getting ready to reinstall the 4-speed linkage and Doug's headers. I'm up in Port St Lucie off of Becker Rd. PM me if you want to stop by. The car is up on a Backyard Buddy in my garage. Makes things a little easier to work on.Anyone use the 63-66 v-8 Schumacher motor mount kits? How are they? For $144 gor brackets, insulators and hardware it's cheaper than buying used brackets I have found then gathering all the other components
I have a set NIB to 273- 340-360 Sold car before I put 340 in- My price $110 plu shipping- live in MDAnyone use the 63-66 v-8 Schumacher motor mount kits? How are they? For $144 gor brackets, insulators and hardware it's cheaper than buying used brackets I have found then gathering all the other components
