2fine69s
69 340-6pak Rag Top
Hey guys.
First, I'm not sure this is the forum for this, so if its not the best place to post it, just let me know. I have a 69 Dart, 340, AT. I need to use a torque strap. Has anyone used the Schumaker, or is there something else better to use. This is engine has 500 lbs of torque and I don't need much engine movement due to the fixed stainless radiator hoses I'm using. I like the idea of rubber engine mounts for less vibration at the stop light, but I will need to limit the engine twist. Any idea's?
