Scored A Set Of Magnum R/T's!!!!!
Took that the wrong way on ya AAR.Check this out,The rocker for a 5.0 stang is same as a Magnum rocker,you do the math....
Better late than never! Some pics of the R/T's.
Are the push rod holes big enough for a flat tappet cam? I have read that they need to be opened up all the way to the VCG rail. Pretty rough castings really, lots of flash and junk in the intake ports. Could use some smoothing.
