Sealing up valve covers
When I pulled the vc's to dbl chk valve lash they were a c-sucker to get off. I shellac'd them to vc and some would still stick to cyl head. I may try the cork sammich in the future.
It doesn't take much clamping force to hold oil back with a good valve cover. I've re-used glued to valve cover cork gaskets double stacked over and over.
Just to be clear - seal the threads with Permatex Thread Sealer, like you would an intake or water pump bolt...
