[SOLD] Semi trailer door hinges
SGBARRACUDA
ROY
Legendary Member
PLANT CITY FL.
I need about 4 Great Dame reefer back door hinges. I'm about to loose both back doors. Hinges are made of pot metal. I thought there might be a trailer mechanic on here that can help me out.
Yes and I'll do something like that if I have to. Figured if I could get the hinges easily I would just replace them. I don't know how hard they are to come by. Thanks
Those are a common service item and you can get them from any semi trailer dealer since they work on all brands and usually have those bits in stock.
There are a couple different depths on the hinges. Would be best to take one with you to a real trailer shop to match up. As said above, they are a very common and cheap. Hopefully you can get the 3 bolts out without the nutserts spinning in the door.
FYI, I went to a local Great Dane parts dealer. Bought 4 hinges and 4 pins for $58.00. Not to bad I thought. Got them on and now I feel safe that the rear doors won't fall off.
Yeah Roy, feel safer not having one of the doors bean you when the hinge breaks. LMAO
I recognized what it was before you turned it into a storage shed. Great Dane had some heavy duty trailers back then, I wouldn't want to wrestle one of the doors by myself.
