I certainly don't argue there are engines that are designed to, and do rev that high. My point is, it is not what the masses are doing. I think there are some street warriors that like to take the tach to places it likely shouldn't be, then tell the world this is normal and how it should be.It all depends on the situation. We truck pull which is basically a drag race with 35.000 pounds behind you. We run the engine to 85-8600 that way when the pan hits it falls into the power at about 7500rpm
