Judge Mills
1971 Plymouth Duster
From what I understand, I need to point the "nose" of the axle down 5-7 degrees, right? and I should tighten everything up once there is a load on the axle, then check again to make sure it is within the parameters?
I am putting in a Ford 8.8..... so the leaf spring perches aren't welded yet....
