I think I will be safe easily to 7500rpm since I use to spin my 340 that high with the stock balancer!
On juice no doubt... LOL
You crazy man! 8)
Nice budget build. Did that block come from my side yard?
Hey Dave,
No this one is based off a 318 Block. I still have that 360 Block you sold me! Gunna do a 360CI Budget build with that one also. Gunna use a Stock Crank, Scat Rods and KB107's in that one. I already have all the parts just need to get it balanced etc.
Get your Stroker going yet??
It's ready to go. I'm saving to take it to Brian to put on the dyno. Been thinking of maybe skipping the engine dyno and put it on a chassis dyno later on when I have the funds. I just got the Dana in and ordered a drive shaft.
Good to hear on the Dana!
I like the engine dyno because if there are any problems to be addressed like oil leaks on the 410 I did. They can easily be fixed. I couldn't Imagine trying to clean up the mess it made while in the car............nightmare!
I took my Supercharged Long Travel sand car into a Chassis Dyno and the guy was gettin on it REALLY HARD before he had the tune dialed in and ended up taking out a ring land running lean! I seen the pieces fly out the headers on fire when it happened. Man was I pissed that day! Guy cost me an engine rebuild!:angry7: Guy didn't care one bit either! and I still had to pay him.
Tracy,
Did you install yours also?
Humm... Why can't they just make these balancers the same size stock ones were???
I,m having similar issues with my AIE dampner(balancer)it,s aweful thick and was thinking useing the March pulleys off of my other car.The pullies won,t line up(water pump,crank)I may have to go with a electric water pump and electric fans?Oh the joy,s for the search for speed.:clock::-D
So, I'm guessing that if this damper was not used, and a TCI Rattler was used instead, there would be no issues... So I guess the question is, is all the headache worth the money saved?
Louis if you take yours off again for any reason do me a favor and measure how much the snout protrudes from the back of the balancer and let me know please. I'm curious if their made the same. They should be since their the same part # but you never know. Thanks, Tracy
That's cool. I was just simply asking, not talking bad about anything...I really admire this build because I REALLY want to build a stock stroke 318 screamer!!! I know about the 408, I have a touch over 11 grand in mine! I don't know where all the money goes! Might have been those damn Eddy heads! I should have used the complete Indy Head top end package!
I won't be home til Sunday I have the measurement u need
written down. You running a chain? Maybe the gear is the diff?
