'70_Duster_340
Any problem w/ running multiple gauges on the same power and ground sources ?? Since there's only a handful of fuses in the block, and so many gauges, does it hurt to run 2 or 3 off the same supply ?? Which gauges draw more ??
Also, what's the best way to connect a hot wire to the fuse block ?? The spade connecters seem to fall out a lot .. Is there a better way??
Thanks,
Kenny
Thanks,
Kenny
