Sharktooth pigtail
Miguel340GB5
Maine
Hi guys,
Just receive my pigtail from Classic Industries and they got wrong connector !?
Someone knows where I can get correct ones ?
Tanks guys
That's weird...after seeing prices for sharktooth pigtails I discovered in a wrecking yard that the same ones are used in 71-72 (maybe others) swinger grills. Saw the same ones on some C body grills as well...
Do you have any old pigtails you could cut and splice the ends onto your new ones?
No pigtail come with the car, wirring is the original of the car. It seems like there were minimum 3 models because I found some NOS and they are all different.
you'll have to make em....if you don't want to cut the factory harness you can make a mini harness with the different ends to connect the two ends you have.
if you don't mind cutting the harness(how i did on my 70 duster)just cut that rubber end off and crimp/solder female ends on and plug em in to the sharktooth pigtail
