Shift arm and spring re-installation help please.
DusterDaddy
sledgehammer mechanic
Holmdel, NJ
I did a search to help my memory along and could not find results.
Is there a trick to putting the shift arm back into the column and get the spring set in the right place?
I took mine apart a few years ago and don't remember how it goes. I checked in the chassis manual and didn't find the answer either.
Any help will be appreciated. Thank you!
You know I did see this drawing in the 73 manual. I guess it was late at night and I didn't look at the cross section. Guess the spring will sort of find its seat....
Thanks!
