When i installed my transgo TF-2 shiftkit i remember having to file a groove over the full height of the valve body. This was on the side of the valve body, right where the gear selector, or rooster comb is if i remember correctly.
Other than that the kit just replacing springs, check balls and requires you to drill through some passages, so that isn't very obvious.
Hope some other people will shime in on this.
