Hell_Fish
- Joined
- Mar 26, 2007
- Messages
- 403
- Reaction score
- 14
Friday and Saturday I cleaned the A904 and installed a TransGo reprograming kit. I used the TF-1 kit and found that the kit is better suited for a 727. By that I mean that with a 60-65 A904, you use very few parts. In all I drilled 3 holes. 2 holes enlarged the passages for the 1-2 and 2-3 shift and one removed a barrier. Added 2 washer shims, 3 springs and the filter and filter gasket. The kit seems like a good kit, but only using 10% of the parts make the cost a little hard to justify. Hopefully I did it correctly. The kit is meant for a pro to install and not a shadetree guy like me, but I think I got it right. The only part I could not do was the modification to the valve body valve to allow downshifing at any speed. Maybe I will pick up another valve from the junk yard and have it machined. I didn't replace the rear band spring either. The instructions said, if it doesn't fit reuse the original, so I figured I would leave it as is with only a 50% success rate.
Anyone else have experiance with a 64-65 904 and a shift kit?
