shifter removal
Brian Mauro
Georgia
Does anyone know how to remove the shifter from the assy, I know it has the detent ball style its a Hurst shifter
You mean the handle? It's either a bayonet style or a bolt in style. Levers held with clips etc. The side cover somes off after you remove the rods.If you are talking the Chysler A-833 Transmission.
I assume this is what you're asking
Yes it is any tricks to getting the detent to depress in the shifter collar, Ok, thanks are there 2 detents or just one that's what I have for the shifter
Here is what the clips look like, you only have to release the one on the driver side. Passenger side of the handle does not have a place for the finger in the clip to "lock in".
Thanks a million, I finally was able to get the feeler gauge in there to release the handle, putting in new carpet
