my68barracuda
I picked up an short tail a-833 iron case tranny some time ago, just the transmission, no rods or shifter, I recently picked up a short tail a-833 aluminum case OD. Complete with rods and shifter.
I had read that the OD transnission has the third gear rod "flipped" over, so to move the rod linkage and shifter to the iron case tranny, is it as simple as fliping the third gear rod over 180 degrees?
It there a reference on the web some where on the proper way to adjust the linkage?
thanks
thanks
