Made themCPEARCE ... where are the photos of new tires and wheels on back ?.....Where did you get that size shim... that is basically what i need to allow 27 size to fit with no issues ..
YesSWEEEEET .... did you stay with Small bolt pattern ?....
Bang dead on 100% correct!Not for 27s; they fit on all As that I have tried, and Fs too.
In fact I can fit 28s on my 1968 Barracuda with just 1/4 inch spacer, and that is with a lowered ride-height using de-arched factory springs.
If you do end up moving the axle back over 1/2 ", you will want to re-visit the rear shackle angle;
