Isn't all money damaged these days?
How many trillions are we in debt now!
"MY" money isn't damaged "enough" to accept an imperfect product.
I wasn't real impressed with the whole damned header to tell you the truth. Pretty crude around the port flange. Looked like some rust around the collector flange. The ceramic coating looked a little thin in the hard-to-reach areas."MY" money isn't damaged "enough" to accept an imperfect product.
Mine came with a couple scratches too, but they were painted black. I touched them up. One thing I learned in this hobby is that there will be little imperfections sometimes. Because you can't see the imperfection, I wouldn't send them back. It's not a piece of fine china. They were stacked with some other headers. I'm sure
Was it dash pads only ???You'll probably have to ding them somewhere else to make them fit anyway. I touched up the blemishes with ceramic header high heat touch up paint.
?????? ?Was it dash pads only ???
I would love to be able to go thru the piles of parts that are returned to Summit.Thanks for the responses. A new set is on it's way and Summit issued a call tag. Hopefully the next set isn't worse. Like 4spdragtop said. Gotta call them out. The boxing should have been better in my view. Not real sure its shipping damage but the box is dinged up and the bag is ripped so... Summit is taking care of it.
Send me that dumpster! Lots of stuff is RTV (return to vendor) but some is non RTV- field destroy. I worked at Circuit City and the cheap stuff was all Non RTV, but the high end stuff was RTV -able. Ever see an Amazon pallet auction? Pallets of returns, shrink wrapped and sold for like 50 bucks. Some stuff is new some stuff is in pieces.I would love to be able to go thru the piles of parts that are returned to Summit.
I just wonder what they do with it all? Mostly like goes in a dumpster.
Dam Boy!!this was needed to clear the T bars on both sides. Dougs headers
Did you try shimming the engine mounts before you bent the headers?this was needed to clear the T bars on both sides. Dougs headers
Well there is your answer "as low as I can get it" when you shim the mounts it raises the engine lifting it away from the T bars.yep the engine is sitting as low as I can get it. Close to spec. Its as if the edelbrock alum heads are a little wider at the exhaust sealing face or a diff angle. The engine doesnt care about the dings in its pipes. 1.03 T bars also but I dont think thats the issue. Theres still only about 1/16 clearance. I cant stand it when the exhaust is bumpin on sumpthin.
I wonder if shaving a little off of the header flange would have helped? Just a little angle up there could really throw the lower pipes and collectors.yep the engine is sitting as low as I can get it. Close to spec. Its as if the edelbrock alum heads are a little wider at the exhaust sealing face or a diff angle. The engine doesnt care about the dings in its pipes. 1.03 T bars also but I dont think thats the issue. Theres still only about 1/16 clearance. I cant stand it when the exhaust is bumpin on sumpthin.
Agreed. But engine was built and installed when the problem was discovered.I wonder if shaving a little off of the header flange would have helped? Just a little angle up there could really throw the lower pipes and collectors.
They hit the inside of the bars. Engine is on the spec height.Well there is your answer "as low as I can get it" when you shim the mounts it raises the engine lifting it away from the T bars.
Heard of fitment issue with the aftermarket heads in other discussions too.They hit the inside of the bars. Engine is on the spec height.
Ouch!They hit the inside of the bars. Engine is on the spec height.
