They are cool I have a friend that has a few.
The Ford N series tractors all have very similar engines....although they did use insulated plug wires. LOLI always thought Model A's were a really cool design---I've never seen any other vehicle that had that sort of approach
There is like four or five of these on eBay at the moment...NOS stuff.Love it never saw that one before. I am kind of starting to collect these oddballs. Have 5 or six of them so far. Kind of goes with the ignition stuff I do.
That spit fire one would be cool on an old Chrysler spit fire poly engine.
I’m running the Crane HI-6N analog (was specifically for NASCAR Winston Cup) along with the Crane matching coil with a recurved Chrysler electronic distributor on my street/strip setup. All works great, Nice well built pieces, has a two dial adjustable Rev limiter too. Should serve you well.I am considering trying this on my 350. Don’t know much about them but I got the whole package fairly cheap and figure what the heck. Maybe next spring it will be revived for a test.
That one may well be a scam. Notice that it disconnects nothing---leaves the breaker points connected to the coilVintage 1970's Sentry Electronic Ignition Kit | eBay
Heck there's another one. By the way none of these are mine....there just popping up on my eBay page.
I blame @halifaxhops for this.....LOL
I'm sure that is what that is. Heathkit sold them or similar as well. I have / had at least one of them and a Tiger--I think--is the one in the round caseIt looks a lot like my Mark 10.
Doesn't those Hurst ones use the breaker points also? As they don't come with anything else but the screws that hold them down by the pictures on eBay.That one may well be a scam. Notice that it disconnects nothing---leaves the breaker points connected to the coil
Notice the one pictured does not REMOVE the points from the coil. A true electronic switching igntion, the points are removed from the coil and go to the box, then the box goes to the coil. This is likely no more than a diode or cap or something in there and likely doesn't do much of anything.Doesn't those Hurst ones use the breaker points also? As they don't come with anything else but the screws that hold them down by the pictures on eBay.
On a side note, the problem with any of the points--triggering-a-box setups is that the points now have such little current going through them that they can lose conductivity from?? fumes/ oil/ etc and then not trigger. This is not a "big" problem, but it can / did happen
Airplane dizzy
