Thanks Ax, and Varlo, I've been bustin *** trying to get the bugs worked out including, but not limited to, fuel leaks at fittings, trans leak, oil leak, coolant leak, performing my best "eyeballed" front end alignment which has been pretty darn straight considering the lack of proper equipment.
Had a hard time getting the side window glass in, adjusted properly and had to fabricate some of my own parts for a couple rollers and other odds and ends that were missing or broken.
Gawd, those quarter glass installs are such a pain in the ***, but after the first one, the second one goes alot smoother.
I plan on building my own headliner out of a fiberboard panel or two pieced together since the factory headliner will interfere with the roll bar.
I'm gonna install the carpet, race harnesses and door panels soon as I save up for that, install some custom panels in the trunk and maybe, just maybe install the factory rear seats but it's gonna take some shaving of the seat frames to compensate for the mini tub geometry deviations from stock.
I was thinking of building a false seat back and bottom but using the false seat bottom as a storage box for tools and stuff.
The trunk floor will be cleaned up with some nice, black paneling and carpeting, and I still have yet to start working on a custom center console.
Eventually I will step up to the plate and have a pistol grip shifter popping up out of the floor to say hi, and the tach needs to be up on top of the dash once I fab up a bracket for that.
This stuff does not happen overnight, maybe for some, but for me this car has taken 8 very long years to get to this point on a poor man's budget so if I can do it, anyone can.
Just takes time, patience and level headed spending enough to keep the Wife happy.
