needsaresto
- Joined
- Nov 13, 2004
- Messages
- 7,603
- Reaction score
- 265
Have them at work,four 6 inch bolts I cut the heads off of.I use them to guide heads on when reassemblying Mopar engines.Learned this from another Mopar fanatic.I have a slot cut in them so I can remove them with a screwdriver.These work in the car as well.I still have to make some for the new hemis.
Interesting. I do sort of the same when replacing a trans or tq converter,install two 8" bolts in the upper bell housing to the motor.It allows for much better alignment of the trans when re assembling.
