Made up a CB Radio base station antenna.
9' Whip and 21" diameter Ground Plane, mounted 16' up off the ground on the front of the shop.
Next step > raise it higher yet. Higher up = more distance.
Big improvement so far, getting it tuned in.
Call this making "communication tools".
Taking things to the next level of experimenting. Now installed a professional grade Base Station antenna at the optimal height of 36'. Swapped this out from my home made antenna.
Has increased my range from 3 miles to 12 plus miles. Here is a pic of me recieving the base station signal with my '76 Truck's Cobra CB and 9' whip at the town of Dundas Minnesota 12 miles South of my base.
At the end of the day I did a radio check on channel 19 from my base. Immediately got a reply back from a guy with a base antenna like mine from the North West 14 miles away just South of the city of Apple Valley.
This guy and 4 of his other buddies are all into CBs in the South Twin City area, we exchanged info and will be looking to communicate together more in the future.
Pretty nice, that's a 25 mile diameter to be able to communicate with others.
Loud & Clear
Someone needs a pedicure.heres an easy one for anyone to slap together,
great on the end of a breaker bar for those extra tough bolts, removing glass and windscreens, makes a great clamp in allmost any position, or even that little bit of extra thump to move something stubborn.
just remember you saw it here first
A brilliant multi purpose tool apparently, theres a beefed up version with a steelcap boot attatched too!!
What is it?Here's one, will post others as soon as I locate em and take pic's.
Do you know anyone that can straighten bumpers in preparation for coating?The big oven is 7 x 4 x 3 and 6'9" is about the longest piece I'm comfortable putting in there. It has a 3" central trolley channel in the ceiling for motorcycle frames, bumpers and stuff. Thanks for asking Idaho!
It's a pipe bender. I wanna see more and what size it will take.What is it?
Thanks so much for that info. I'm a gear head but have never gotten in to any of the body work due to time, space and equipment restraints. I learn something g new every day.Maybe TriCity?
Keep in mind though that powder coating over chrome is NOT the proper way to do it, though lots of people do. I'm not one of them.
The absolute best way is to get that chrome chemically removed at a chrome shop first because it's faster and a lot cheaper than trying to blast it off, especially a good old triple plated nickel / copper / chromium job. Even trying to get a decent blast profile on it takes hours, and even then is half *** ... because any impact can take not only the powder layer off but the chrome layer as well. Then the elements get to work on it and before you know it, the whole job is coming off in sheets as rust forms in between. It's called "creep."
When that happens, it isn't the chrome shop whose reputation suffers. It's the powder guy who is rightly at fault for not doing it properly the first time by applying the powder onto a bare, impeccably clean substrate (the blasted bare steel bumper).
Put your chosen powder shop on the spot by asking exactly what prep your bumper will go through. If "I'll rough it up with a ScotchBrite pad" is part of the answer, you'll get exactly what you pay for: a half *** job.
Hopefully whomever you get to straighten them can also strip the old chrome off for you too. If you don't get it down to bare metal, you're wasting your money and tempting Fate that it's going to last.
Wow! That's really homemade.
Tri City Plating....right there in The Volunteer State! Elizabethton, TN, near Johnson City. They are the best there is at replating bumpers!Do you know anyone that can straighten bumpers in preparation for coating?
That's nice, but why just tack welds?
I dont think it needs more than tacks. I have a small piece of angle iron welded under the V to prevent it from pushing apart. Its for stuff less than 1/8”That's nice, but why just tack welds?
