Show Your Big Block A body!
dart blower, great looking hotrod you have there, but where's the barrel valve and the injector nozzles or is there a carb in the hat or in the blower? how's it work?
Thanks for asking. i make first intake from offy 2 x 4, and nozzles is just on manifold on intakes ports.
i use first 720 cc injectors and holley 950 commader box.
the engine works just well, only my mistake was; i driven too lean :D
so 4 pistons burned littlebit and one crash came to one cylinder; the block was used on racing before allso.
But goes easy 10,6 with 1/3 pedal.......
Now making new engine, -230 case 400 + 4,15 crank and bme al rods.
stage V cast heads and making new intake for that 14-71 blower; offy tunnelram; need much of changes for blower
the injectors comes now 960 cc.
and transmission will be PG
if somebody like to see hows working go on, i will show the pics; i just starter this project :D, takes about 6 months, i think
Here's my 71 Duster with it's newly rebuilt 440. 11.5 comp KB pistons, 509 mopar cam, 1.7 alum roller rockers, 950 proform DP carb, edy Tm7 intake.
Going with a narrowed rear end soon...
Updated Pics...
Now with upgraded narrowed rear end, moser axles, hoosier DOT 29x14.5x15 slicks and 15x10 autodrag centerlines.
I like the way it sits... Ready for lauch!
there certainly is alot of nice looking bigblock a-bodies. dartblower, keep us posted on your progress please.
Yea, i will do it :D
I make some video (s) what have happen on last 4 years;
I travel to Estonia next night, so this will be continues on next week:
many interesting stories about blowers :D
watch
Beautiful car Chasb, is that a factory 4-speed?
Grant
Tanks
Just browsing and realized I never responded to this. Yes it is the factory
A833, soon to have a 4 speed overdrive gear set installed from Passon Performance. (Will give me a 2:84 ratio 4th gear for cruising)
Chas
pushed it down the drive way for a test fit on the trailer
This demon is greate !!!
i have allso tryed to buy a hat like that; so expencive :D
here is my first big project dart LH41 :D, fuelinjections are greate and expencives :D
sorry, SB engine........but still in my garrage...
Here's my 72 duster. Original 340 car. Now pump gas 383 with spray. 4.10 rear with SS springs and offset spring pkg. 3000 convertor and T/A forward manual valve body. 12.35 on motor. Haven't used spray at track yet.
Here's mine , very boring original 383, 4 speed car , 3.91 gears and stripe delete ...
:toothy10: I hope you`re being sarcastic because there is nothing boring about an original big block 4 spd. car! :cheers: Oh , and it`s green!!!
Yes I was being VERY sarcastic , there is NOTHING boring about this car , and it will be less boring when I install the 383 based 450" stroker I've been building for it .
If it wasn't an original big block car with only 56k miles I'd put my HEMI in it instead of in my 69 Bee ...
