Show your wheels
yes it did! i left the spacer in for good measure,and i like the extra width. i changed my carb out and i have a leak to fix,so i haven't even driven it yet with them mounted.
Small bolt ralleys, spray bomb met.graphite, generic sigma supreme TR 60's.
I had to try a pair of Used 225/R70'14 on my ralley's
I see you took your lower trim off yellow68runner.
The 66 signet looks great. Are you running a V8? and do you still have the lower trim??
hey, johnparts, those are the wheels that I was looking at buying, they look great. I was just wondering if you had any clearance issues at all? And what do you have for tires on them?
Yeah they rub but here's the thing I didn't put them on the car they were on it when I bought it. Also there is a Ford rear end in the car and the front is lowered so that is most of the rubbing issues. Oh and the fenders are rolled
Alright, thanks for the quick response, I just called on an 8 3/4 today. Plus I'm pretty sure the duster has a bit more room for the rear compared to the scamp.
I`ve never been keen on the larger diameter rims on our cars but after posts 33, 34, and 35, I`m starting to become a believer. Nice wheels guys!
Mickey Thompson 15x3 front 3.5 x 26 front runner ,15x10 rear 4.5 back space 9x 30 Hoosier light weight radial
Some tweaking at the front of the wheel well for clearance
[/IMG]
[/IMG]
[/IMG]
Speedy 14" x 6" fronts, 14" x 8" rears... Supercat Tyres 205's and 215's.. Will go to larger tyres on rear when these are done... These wheels are similar to older Cragar SS...
finally got rid of the 13's
B F Goodrich radial T/A's
225/70R14 on the back
205/70R14 on the front
now cruises @ 60 mph - 2750 rpm
14" X 5 1/2" (sbp) Rallyes with P195/75R14 (Front) & P215/75R14 (Rear) Toyo Extensa A/S tires.
Picture taken at the Woodward Dream Cruise.
As seen in my current signature pic, these are my 15" wheels...still hunting for the perfect 17"s!
Rota RKR 15x8/0mm offset rear, 15x7 (modified)10mm offset front.
Old School, Weld Draglites
15 x 7 5.5 bs rear w/ 245/60/15 , 15 x 7 3.5 bs Front w/205/60/15
Bruce
