Shroud attaching hardware?
buck351
Campton Hills, IL
Ok, I finally got a shroud for my 67 dart. I don't have the attaching hardware. What did they use to attache it to the radiator?
From what I have seen so far it's just some C shaped blind nuts and correct length bolts for the raised mounting spots on the radiator.
The U nuts they used there are quite small as stated above. They fit the offset in the flange.
The bolts were about 1 inch long with kep washers. Some claim those are special bolts. I dont know for sure. Maybe there head is under standard size or the kep washer is under oe over standard diameter and/or thickness. If you have to have exact, I've seen them on ebay before.
