68Dart340
Which windows are you wondering about? I've had all of mine out of my 69 Dart. The quarter glasses come out after you remove the 3 retaining bolts holding the glass to the regulator. You have to remove your inside finish panel
in order to see the bolts. Its easier if you leave the window in the up postion to get to the bolts.The door panels have to come off to remove the door windows. You can get to all the attaching hardware from the access in the door .The vent window frame wil also have to come out as that slides over the door glass on the front edge of the window. Be prepared for a headache when you get back to aligning the quarter glasses to the door and the roof rail. Not one of Mopars better design ideas. Been through all of that mess and it was no fun.
Good luck!
416stroker
