Strut rod
The bushings in the front end are fairly simple and self explanatory
Upper control arms have two in each arm "upper control arm bushings"
Upper control arm has 1 ball joint "upper ball joint"
Lower control arms have one bushing "lower control arm bushings"
and one ball joint "lower ball joint"
Strut rods have 4 rubber pieces plus washers to do both sides, I.E. 4 rubber pieces for a whole car
If you have a sway bar, it has rubber bushings it pivots on, and "link bushings" or similar name for the short vertical connector rods--two rubbers on each end of each rod, IE 8 pieces for whole car for the vertical links.
Except for the 4 tie rod ends, drag link (center link) and idler arm, that's all there is to the moving parts in the front suspension
