hemitheus
19? Plymouth Scampenstein
I got a dual master but no plunger. my single plunger is substantially different than what I am expecting. can I use the single plunger or should i get a plunger from a dual?
No. Get the plunger (piston) for the dual cylinder since both wells in the master cylinder are in use. Anyone else out there bought a master cylinder without a piston? You'll also probably want the distribution block and lines that go with the dual master cylinder.I got a dual master but no plunger. my single plunger is substantially different than what I am expecting. can I use the single plunger or should i get a plunger from a dual?
