Back when mopar did the last 6pack repop for restoration parts I thought the price was stupid, I can’t exactly remember what what it was, but I thought it was way too much. Oh boy was I wrong, I should have bought a dozen of them.yeah, just looked.. Mancini wants 3600 for a brand new setup.. and guys are asking more than that for used (prolly cause numbers).. if i found one for like 1200 i would consider it but meh..
If I could go back 35 years I'd buy and invest in a lot of things that are worth a fortune today, I remember when I could of bought a fully restored T/A Challenger for $25,000 and thought it was crazy money and $50,000 Hemi cars.Back when mopar did the last 6pack repop for restoration parts I thought the price was stupid, I can’t exactly remember what what it was, but I thought it was way too much. Oh boy was I wrong, I should have bought a dozen of them.
At one time I had just sitting around sets for a 440, 383 & 340.Back when mopar did the last 6pack repop for restoration parts I thought the price was stupid, I can’t exactly remember what what it was, but I thought it was way too much. Oh boy was I wrong, I should have bought a dozen of them.
Heck yeah put it on there. Why not? It'll need more than a "basic re-ring" because it'll need some compression and some cylinder head flow, but you can certainly make it work.okay i stumpled aver this Six Pack and the price was right. I know a 340s would be cool but the only thing i have is a 318 which i plan to rebuild the cheap way. Hone it, , new rings and so on, a basic re reing job.
What you guys think, is it a bad idea to use the sixpack in this ? And if the answer is yes , what cam should i use?
Car will be a 66 Barracuda with a 904 automatic not sure about the rear end ratio. Converter stock.
Back in the 80’s, Quaden dodge sold their 68 Hemi Superstock Dart for 85K. That right there should have been a precursor to Hemi car values to come as it was a locally raced and relatively unknown car without the big name pedigree like Landy’s dart or the red light bandit.If I could go back 35 years I'd buy and invest in a lot of things that are worth a fortune today, I remember when I could of bought a fully restored T/A Challenger for $25,000 and thought it was crazy money and $50,000 Hemi cars.
Its always hit or miss on old cars.Back in the 80’s, Quaden dodge sold their 68 Hemi Superstock Dart for 85K. That right there should have been a precursor to Hemi car values to come as it was a locally raced and relatively unknown car without the big name pedigree like Landy’s dart or the red light bandit.
A 2 barrel until you need it.Speaking from experience here..... I put a 6 pack set up on the 318 in the 69 Fury ragtop that I had for 17 years. All stock original long block, except I put a 68 340 cam in it. Stock convertor and 3.55 gears. That land yacht would still pull 18mpg if I kept my foot out of it.. not a rocket off the line, but top end out the yingyang.
Nothing.K, i do have a question and this is just a question not an attack.... a 318 is pistons and a crank, if you put on good heads/cam/springs that's the same as you do on any motor to spin rpm, what is holding a 318 back from high rpm compared to a 340 if cam/heads/springs are equal?
All the center carbs are "350 cfm" . Actually, if rated as if they were four barrels, total flow is less than 1000 cfm, in spite of the "1350" b.s.Question for the group. Are the small block center carbs 350 cfm or 500? Just curious
The 365/375 horse 327 had a cam in this range. Speed Pro still sells it. Put it in your 318 along with a nice intake and carb and some headers and see where you go. I bet that 327 had 10/1 compression at least which the 318 lacked. A 300° cam is pretty nasty especially in a small cube engine.My opinion only:
A few cubes difference between a Ford 302, Mopar 318, and a 327 chevy, doesn't mean much. The difference is, there were real performance versions of 289/302 Fords, and REAL performance versions of the 327. That is not true of the 318, and it's reputation suffers.
Put equivalent hi performance parts comparable to the 365/375hp versions of the 327, you should get comparable results. Trouble is.... Mopar never did.
As for camming it,okay i stumpled aver this Six Pack and the price was right. I know a 340s would be cool but the only thing i have is a 318 which i plan to rebuild the cheap way. Hone it, , new rings and so on, a basic re reing job.
My opinion only:
If I remember right, the 365 solid lifter 2.02 head motor had 11 or 11 1/4 to one.The 365/375 horse 327 had a cam in this range. Speed Pro still sells it. Put it in your 318 along with a nice intake and carb and some headers and see where you go. I bet that 327 had 10/1 compression at least which the 318 lacked. A 300° cam is pretty nasty especially in a small cube engine.
Speed Pro # CS118R 254°@ .050 295° adverttised duration
.485 lift 114° Lobe separation.
The Chevy guys say it comes on strong at 3500 to redline. (no idea what that is but guessing 5500+)
I totally get that; my 360 was singing a lovely tune at 7200, with a 270 cam. I only shifted at 7200 because I was ascared to go higher, lol; the engine was willing.,It would have been quite a bit faster if I had shifted at 6500. DOH!
That right there is a killer deal my friend.Its always hit or miss on old cars.
Around 5 years ago the WV Hemi baracuda was for sale, in race ready condition, with 5 spare hemi engines in parts for 80K. It was a real SS Hemi car.
Need a 340 cam or a tich more. Port the heads and use inexpensive LS 5.3 valves. 1.9"/1.55". You do need to install either the LS powdered metal guides or bronze guides, with the 8mm diameter. That also opens the door for beehive springs, retainers and locks.okay i stumpled aver this Six Pack and the price was right. I know a 340s would be cool but the only thing i have is a 318 which i plan to rebuild the cheap way. Hone it, , new rings and so on, a basic re reing job.
I believe Magnums had 8mm valves. I do like the idea of beehive springs.Need a 340 cam or a tich more. Port the heads and use inexpensive LS 5.3 valves. 1.9"/1.55". You do need to install either the LS powdered metal guides or bronze guides, with the 8mm diameter. That also opens the door for beehive springs, retainers and locks.
Go for it, only 22 CID difference. Just need the port flow and velocities.
