.Stroker pounds the crap out of the mains, post #30.
Huh?
I can name a couple of 'production' strokers that seem to last just fine. By that I mean they have considerably longer strokes than other engines of comparable capacity. Olds 455 has a 4.25" stroke, 1/2" longer than a 440. 455 Pontiac is right behind it with a 4.21" stroke. Neither engine known for pounding out mains.
Isn't the olds engine known for not having very much meat in the webbing of the block. An this causes the main caps and the block itself to shift around. So therefore they run looser clearances on the mains to keep the crank from hitting the bearing when the block shifts?
