Getting ready to paint and assemble the short block, nice and clean!
Minimal clearancing at the bottom of the cylinders for the rods.
Those pistons with that ring pack are amazing. Make sure you don't have a traditional .005" clearance or it will sound a little dieselly. Run them at their recommended clearance which is .003" on a 4032 piston. J.Rob
Super nice build , really like Mahle pistons light as can be and make no noise , used them on my 340's , as for the rest of your build , i'm using the molnar crank and rods as well , good stuff should make plenty of power .
Get ready to break out the hammer and grinder. Getting the milodon parts to fit is a giant p i t a.
I think i would paint a nice set of boobs around those to compliment the bumps..
I bilt my stroker last year, it's eerily similar to yours.
Short block:
360 based 414
4.06 bore
4.0 Molner forged crank
6.123 Molner rods
Mahle inverted dome pistons 16cc's
.276 top ring down
~ -.002-004 in the hole
10.87-10.89 compression
.040 custom Cometics
Quench .043 not sure on an inverted dome?
1,1,2mm ring pack .016 top .020 2nd gap
King bearings throughout
.002 main clearance
.0028 rod clearance
1784 bobweight
Arp main, rod and head studs
Milodon road race pan and pick up
Modded windage tray(due to stud clearance)
IJ crank scraper
Melling 72HV(used lol)
Mopar magnum one piece oil pan gasket
MP .557 cam 4* advanced at 106*
Rollmaster billet chain
MP chain tensioner
Flowkooler water pump
Side entrance rear freeze plug cooling
Trick flow balancer internal
Top end:
Howard's EDM solid lifters
Milodon valley tray
Smith Bros custom 5/16 ball/cup pushrods
Erson 1.6 roller rockers
B3re geometry correction
Billet rocker hold downs and studs
Lashed to .020/.024 hot
HD distributor gear/pump drive
A crap ton of driven assembly lube
Trick flow 190 heads
Mopar M1 modded intake (burr finish(done by me and probably a hindrance ,I'm not a pro), epoxied to square bore, back passage coolant lines.
Hvh super sucker (left on for every pull)
Autolite 3924's
A friend's msd distributor and wires
A friend's Holley 750 set up for his 408.
Mix of 91 and 112 unleaded. So 95 octane?
Results:
Dyno's onsite weather station
5200 foot elevation
90* today
25.7 in
42.3 relative
546hp/557tq corrected
Obligatory orange block, cam bearings & main bearings in. Main studs and crank are in, pistons and rods installed, cam and roller timing chain installed and degreed in..
View attachment 1715606037View attachment 1715606041
View attachment 1715606038 View attachment 1715606039 View attachment 1715606040
View attachment 1715606042 View attachment 1715606043
great numbers i have a similar build but used 23cc dished pistons best i got was 510 hp 560 tq , ut that is about to change hope to get numbers close to yours when the 13cc pistons go in . thanks for posting the numbers , give me a target to aim for .I bilt my stroker last year, it's eerily similar to yours.
Short block:
360 based 414
4.06 bore
6.123 Molner rods
.276 top ring down
.002 main clearance
.0028 rod clearance
1784 bobweight
IJ crank scraper
MP chain tensioner
Top end:
Milodon valley tray
Autolite 3924's
Results:
5200 foot elevation
90* today
25.7 in
42.3 relative
i got mine from hughes but molnar sell them as wellWow. Excellent build! Where are you getting the molner crank and rods?
torn between those and scat.
get the molnar set just my opinion , shop that built my engine suggested i get it over the scat or eagle if i had the money , it's what they use on their own carsWow. Excellent build! Where are you getting the molner crank and rods?
Short block:
360 based 414
4.06 bore
6.123 Molner rods
.276 top ring down
.002 main clearance
.0028 rod clearance
1784 bobweight
IJ crank scraper
MP chain tensioner
Top end:
Milodon valley tray
Autolite 3924's
Results:
5200 foot elevation
90* today
25.7 in
42.3 relative
I noticed that you used a chain tensioner...Aren't those tensioners intended for the non roller timing chains? Seems like a roller timing chain. would eat into the nylon pads?
Here I was hoping for a Jeep build
Only thing better than a 4.0 would be a 4.25
what's the delta in cost?
Looks to be an Airgap.WHAT INTAKE YOU running ? if it's an air gap forget it runs out of steam at 5600 - 5800 . i got rid of my ported gasket matched air gap for a victor will have it on the dyno soon to see if it makes good power to at least 6500 . air gap made great torque 560 at 4600 but hp dropped after 5600 rpm
