[Found!] Slant 6 225 rods
Looking for a set of rods for a 225. Preferably reconditioned or a good used set that are still in spec. Thank you very much.
Cast crank or Steel crank?
if you are looking for cast crank rods I have a set as removed from an engine. Pistons still on them. Will fit in a large flat rate box and will be cheap. Send a PM if interested.
