mopars4life
Slant 6 225 from a 74 Duster I am parting. The engine turns over by hand and makes compression - no idea of condition as it wasn't running when I got it. Complete from air cleaner to oil pan. Manual trans engine. $100 takes it -
Complete front suspension from the same car -k frame small bolt drum brakes and upper and lower control arms. K frame is the more desirable spool mount. $200 for everything.
Local pick up from Northern VA on both items.
