Those3/8" holes between the valve cover and manifolds, on the manifold side, are there specifically for lifting the /6. if you put a bolt in both holes, and chain to both bolts, it will be at the correct angle to remove and replace the motor. Don't use the manifold studs for this, they will likely break.
