Slant 6 to 318 conversion...
French demon
South of France
Hi guys
I envisage the possibility to swap my slant-6 to a 318, but want to keep my A-230 3-speed gearbox.
A non-irreversible swap as I would use a Schumacher (or Trans-dapt) L6/318 conversion kit on my original K-member.
Is my slant-6 clutch compatible with the V8? And what's the bellhousing part number?
:thankyou:
François
Slant 6 clutch is different than the v-8 clutch
Bell housing I need to check on the PN.
Unless someone else chimes in.
Other than wiring harness - this is not non- reversible. Just some work, that’s all.
But you know what they say- go V8 and never look back.
Syleng1
The 2892482 or 3515734 bell housings should work for you. Get matching flywheel and clutch for it.
