[SOLD] Slant Six 400 HP Ram Clutch/Flywheel/Pressure Plate
MidnightSwinger
Woodland CA
Installed but never run. Bought in December of 2023 from Summit Racing. Two small imperfections on the pressure plate face. It was like that when I got it from summit.
This is for the small register pre ‘68 crank, but it could be machined for the later crank.
Includes mcleod pressure plate bolts and ARP flywheel bolts. Save a few hundred $$$ and get a real clutch for your slant.
$575 picked up or $615 shipped from 95695 Woodland CA.
The clutch and pressure plate will work for the small block early a application where you need the 9.5” clutch. The flywheel is slant six specific.
Open to offers, and trades. Building a 360 and looking for a solid cam, a higher stall torque converter etc… I also need a front sway bar for my 67 Barracuda.
