MN1968Valiant
In College's Stranglehold
I'm looking to do a conversion to an 833OD conversion behind the Slant 6 in my 68 Valiant. The following is a list of parts I foresee needing in the course of this swap. The only three parts I have secured thus far are a bell housing, inspection shield, and clutch fork. Everything else is up in the air. Feel free to post anything useful you have that might for my swap or anything big that I seem to be missing from my swap list. Thanks in advance.
Part
Bellhousing
Inspection Shield
Flywheel
Pressure Plate
Clutch Disc
Clutch Fork
Z-Bar
Pedals
Transmission
Transmission Linkage/Shifter Rods
Shifter
Shifter Hump
Throwout Bearing
Miscellaneous Swap Parts
Carpet
Steering Column? Maybe [Eventually]
Part
Bellhousing
Inspection Shield
Flywheel
Pressure Plate
Clutch Disc
Clutch Fork
Z-Bar
Pedals
Transmission
Shifter
Shifter Hump
Throwout Bearing
Carpet
