Slantsix64
hey there guys was going to pick up a six motor checked it out runs good did a compression test 140 psi average on the cylinders. my question is if the motor has 140 psi what the compression ratio on the slant would this indicate that the head has had some milling done to it or is that just stock psi on a regular rebuild on a 1971 slant six 225. i am asking this cause the owner only know the person he got it from did a rebuild prior. any advice is welcome thank you!
