BillGrissom
I got a new electronic distributor for my 64 Valiant 225 cheap ($35 ebay), in a Mopar box PN 3755468, though metal tag is 3755467. It was missing internal plates, but had vacuum advance (VA). My guess is a dealer mechanic robbed the internals to fix another distributor since the tag was loose in the box and VA wasn't screwed tight.
I got a new coil plate for $4.50 at rockauto (bought 2, jump on that!), but needed the baseplate in photo below, so removed the one from my points distributor. The coil plate fit on it like a glove, so perhaps same PN (no stamp). The distributor bodies appear identical (points on left), though the shafts differ. The points base plate has 3 copper standoffs which the points plate slides on. That makes a needed electrical connection, un-needed with a coil pickup, so perhaps they simplified the baseplate design but otherwise kept the mechanical dimensions. I'll eventually get a baseplate for my points distributor to have ready as backup. If anyone has one lying around, PM with price.
The VA differs between my points and electronic distributors. I suspect my points distributor is a recent rebuild, since very clean and the output wire looks new. The points plate has a single hole for vacuum advance, on the outside, which the VA fits. There are no labels on the VA.
The coil plate has 2 holes for VA. One is hard to see, underneath the coil. The VA rod curves inward to fit the inside hole. The VA has stamps 375041 (?, hole thru the numbers) and 8.5R (rod), and paper tag 3282.
Another kink, I ordered a VA from rockauto (cheap), described as "improved mileage" (hasn't arrived). A working hypothesis is that the "bent VA" acting on the inner hole brings on advance sooner, which improves combustion at the risk of knock, which probably works better with the leaner mixtures of late 70's engines.
I don't think quick advance is a big risk, since many Jeep off-roaders connect their VA to direct manifold vacuum. They they say that avoids stumbles when they give it throttle to climb rocks (don't ask me why). Anyway, I plan to eventually add EFI, O2 sensors, and a knock sensor, so I won't fear pushing the advance limit.
A few other issues.
I know nothing about the adjustment slot on the base clamp of the distributor. Right now it is in the middle. I guess it allows positioning the VA to not bump the motor mount or fuel pump (went electric). I expect it won't need changing, since weren't all slants the same?
I read posts about "short tip" rotors causing misfire. My points distributor has a grey rotor with tip protruding ~1/8" past the plastic. I got the United Ignition Wire Tri-Pak tune up kit, PN 1-7600. It's blue rotor has a tip that barely protrudes past the plastic, so I thought "short tip problem", but when I installed both on the shaft, it actually protrudes slightly farther, so just has more plastic. I am waiting for SSD or another guy to say "UIW makes junk", but the blue cap has copper posts and is labelled "made in USA". I know nothing of them, I just liked the price on rockauto.
Instead of a Mopar igniter box, I installed a GM "8-pin" HEI module and coil. I'll post more once I get it running, and tell you the polarity that works for the pickup wires.
Please add any info you have on slant distributors. I am guessing I don't need a capacitor at the ignition coil since I don't think the GM system uses one, and I think noise was only a problem with AM radios, plus can add a filter at the radio if needed. I understand that the small capacitor inside the points distributor was just to extend the life of the points.
A few other issues.
