Looks like [email protected]
I am in the process of setting up a slant head to use Chevy 250 I6 valves, 1.720 intake and 1.500 exhaust, have the 11/32 diameter stems.Well, I finally was able to get a "little" done here. Got the rod bolts replaced with gooduns, rods resized and pistons mashed on. Also got the head cleaned and magged, but it's still at the shop. Takin him the 318 valves Monday so he can hog the heads out for those and do the valve job. Then it's on to my head porter. Slow, but forward motion nonetheless.
Does the person porting your slant six head provide flow numbers? I am curious concerning what you and MOPAROFFICIAL get for flow across the lift.
Yep, that would have been a great head, for a turbo car. You were not necessarily making a hard choice when you sold it.
I am reading through the threads now, thanks,Absolutely he does. If you follow the link I provided a few posts back, you can see the first head he did for me. The flow sheets are posted there.
Those numbers are also at 28 inches?I've never all out ported with the 1.6 something stock valve, but I did gasket match n bowl port one that I noted.
.1-50
.2-105
.3-142
.4-164
.5-170
.6-? That's all i have written down for that 1967 / head. No ex.
I do however port with the 1.7/1.44
Here's what I have written down.
....int....
.1-58....
.2-111.6
.3-152.7
.4-176
.5-182
.6-189
.65-192
They're close. I work the floor more, that's where it is. Ime.
Yes.Those numbers are also at 28 inches?
Killians?
What were the #'s again, you have the link still? They were pretty looking I remember.
Thanks for the link back to the 2012 Porting Post. Got through all six pages. I had forgotten all about that, knew of it back then as I had posted in it.
My how time flies.
Good Luck with the new head.
What did you figure out on the gear drive?
