I was driving home from work and it just died so when I got it home I started to look over everything. I took the ignition coil wire off the distributor and stuck it next to my alternator and turned it over. About every fourth revolution I would get a spark. My father thought it was the ignition switch because he had this problem when he was a kid and so I changed it out and it made no difference what so ever. So then we thought it was the brain box and since I have lifetime warranty on mostly everything under that hood I changed it out and then the spark changed to being intermittent it would spark twice then stop then spark a few times in a row then stop again. So we jumped the positive terminal on the coil from the alternator and nothing so we swapped that as well and she started up right away. It was a crappy idle for a bit then as it warmed up it somewhat went away. So I drove it to work and on the way back it died again then caught back up and idled very rough then just died. Now I have no spark and I cant figure this out at all.. Everything else was changed about a year and a half ago and I have seen nothing wrong with anything. I pulled everything off and plugged it back in about five times to clean the connections and feel for how tight everything was. The car is a 1973 dodge dart custom 225 /6. If you guys have any questions please ask!!
