slant6-360swap & Alterkation?
KramerSwinger70
70 Dart Swinger360
Rohnert Park, CA
http://www.engine-swaps.com/index.html
just discovered this site regaurding mopar engines swaps for slant six to 340/360. But i also plan on doin the Alter-K-Tion front suspension. Am i goin to be able to use the Slant6 K member for the front suspension? does it even affect it? I was hoping to at least mock up my 360/904 combo soon but if i need a v8 K to make the RMS system work, im gonna have to make some changes in the build
Alterk replaces the entire front suspension including the k frame.
If you put in the alterk he asks what motor you're using. If your plan to run the 6 with the alterk and then swap a 360, he might the bracket you need. Best thing to do is call him and ask.
