I have 2 1/4 room and the water pump is in the center
Need a fan that will clear pkz help
Motor is a 550hp 408 street strip car that radiator is a champion
http://www.forabodiesonly.com/mopar/showthread.php?t=281911&highlight=taurus+fan
Check this out. This fan is for a 22" radiator.
Here for a 26" Champion:
https://www.dropbox.com/s/wdvxqfd1tnhcpy3/Electric Fan 26in Radiator.pdf?dl=0
I am not sure on the thickness though.
Wjat i had that didnt cool crap was 2 champion fans with no shroud and it couldnt keep it cool at all the radiator is a 4 row also
Ill look into 2 better 10 inch fans
Thanks for the Spal PN; that actually looks decent, as opposed to the cheap thin balded fans...Spal #2052 might work depending on where that teet on the end of the pump lands.
