TXOval
340 stroked to 416
What battery?
I still believe your cable size is part of it.
Electric fans?
Electric fans?
I did exactly that when testing today. Yes the ground cable from frame to negative terminal was warm, but so was the positive cableAfter you try cranking it when hot, go feel your ground cable at the battery
warm cable means it is to small......I did exactly that when testing today. Yes the ground cable from frame to negative terminal was warm, but so was the positive cable
yes. called 2 aut.Alright I'll look into getting all new cables, 2/0 is the size I need?
Go to a welding supply store, buy cable in bulk....by the foot.....yes. called 2 aut.
Should be........Have not bought any in a long time......copper has gone crazy price wise....Is it cheaper than buying it from somewhere like Summit?
Attribute | 2 AWG Wire | 2/0 AWG Wire |
Diameter | 0.2576 inches (6.54 mm) | 0.3648 inches (9.27 mm) |
Ampacity (60°C) | 115 amps | 135 amps |
Ampacity (75°C) | 130 amps | 155 amps |
Ampacity (90°C) | 150 amps | 180 amps |
Resistance (Ohms/1000ft) | 0.624 | 0.393 |
those are for 115 volts. 2/0 wire good for 500 amps at 12 V. Or so....I might end up needing to run larger cable than 2/0 then as I have a high output alternator putting out around 215 amps
You might be able to get additional 2AWG wire and double up the runs! Might be cheaper than 2/0 wire.Alright, ill look into getting some 2/0 welding cable. I'll be sure to post weather or not that was the problem
Tim where did you get that chart? There are all kinds of them, and "some disagreement" LOL. AC ampacity is not to be used for automotive. Also, FOOTAGE of the total wire matters2 AWG Wire
2 AWG wire has a diameter of 0.2576 inches (6.54 mm) and is commonly used for applications that require high ampacity, such as industrial equipment, heavy machinery, and large appliances. It has an ampacity of 115 amps at 60°C (140°F), 130 amps at 75°C (167°F), and 150 amps at 90°C (194°F).
2/0 AWG Wire
2/0 AWG wire has a diameter of 0.3648 inches (9.27 mm) and is larger than 2 AWG wire. This wire is commonly used in power distribution and transmission applications, as well as for grounding and bonding. It has an ampacity of 135 amps at 60°C (140°F), 155 amps at 75°C (167°F), and 180 amps at 90°C (194°F).
Differences Between 2 AWG and 2/0 AWG Wires
The main differences between 2 AWG and 2/0 AWG wires are their diameter, ampacity, and resistance. 2/0 AWG wire is larger in diameter than 2 AWG wire and has a higher ampacity. Additionally, 2/0 AWG wire has lower resistance than 2 AWG wire.
Attribute 2 AWG Wire 2/0 AWG Wire Diameter 0.2576 inches (6.54 mm) 0.3648 inches (9.27 mm) Ampacity (60°C) 115 amps 135 amps Ampacity (75°C) 130 amps 155 amps Ampacity (90°C) 150 amps 180 amps Resistance (Ohms/1000ft) 0.624 0.393
I used this same supplier. Had great service from them and got everything needed in 1-stop shopping there. Highly recommend this supplier!My 2/0 wire is 1/2” in diameter, 5/8” with jacket
00 Gauge (2/0 AWG) Battery Cable with Ends OFC Copper Flexible Stranded UL MTW/THW/SGT
Where I got my cable and a lot of information
Then get a remote starter switch. Any auto parts store will have one cheap.Just checked for voltage drop, 12.61v at battery, 12.61v at alternator, and 12.60v at starter. Can't test while cranking as I'm alone
