@Phreakish that is a great idea! Really, I would have never thought of that.
That really is a solid idea... can you post up a closer photo of the interference?
Here are some close ups of the interference. Its the metal line that comes out of the back of the ps pump that hits the drivers side head. Now onto trying to look up which bolts go into water jackets lol.
Ok 1 more dumb queation... these are the 2 spots for the longer ARP bolts correct. Also most say to torque them down to 95 ft lbs, but arp directions say 100 ft lbs... so which is it?
Welp this sucks... I dont know if I will ever buy arp head bolts again... first bolt going to 45lbs with a 6pt socket and it strips... got it to hold tight enough to keep going but when I got to the 100 ft lbs setting it stripped again... idk if I will even be able to get it off now... every other bolt is at 100 ft lbs...
Good go!Well... ARP bolt is a 14mm now... I banged a 14mm 6pt socket onto it and was able to get it out. I guess I'll just reuse a stock bolt there and give ARP a phone call tomorrow
True, you wont know any difference until the bolts flex and work harden until they snap off. Hopefully that doesn't happen on your heads. But it's very common on those.@mopowers I think the rocker arm shaft saddles are good. I wouldn't really know any difference, but mine seem to fit pretty nicely.
@pittsburghracer yes that is a brand new ARP head bolt, just took it out of the box. I have a craftsman torque wrench and was using a Husky 6pt socket.
Regarding the arp head bolts. Ive never had a problem with my sockets before but if a stripped bolt head is the worst of my problems with putting the heads on then I think I'm doing pretty good. At some point I'll order some different rockers, but for now these will be fine. I wonder how much more power the car will have now that I have the cnc sm heads... maybe I should have stepped up cam sizes... nope not going down that rabbit hole. I do need to invest in a new torque converter one day, my stock rebuild one is probably the weak link now.
