[SOLD] Small block (360) misc. internal engine parts.
Locomotion
Florida
Piston Rings -
* Childs & Albert RS 10477-25, 4.020" bore file fit, 5/64"-5/64"-3/16", low tension - $90.00
* Childs & Albert RS 10477-45, 4.040" bore file fit, 5/64"-5/64"-3/16", low tension - $90.00
* Mahle/Perfect Circle 315-0034 .035 , 4.030" bore file fit, 5/64"-5/64"-3/16", std. tension - $90.00 (SALE PENDING)
* Hastings 2M 5505 035, 4.030" bore file fit, 1/16"-1/16"-3/16", low tension - $85.00
(I believe these are low tension oil rings. Hastings website & Summit doesn't say, but Ebay ads say "low".)
Main Bearings-
* Clevite MS-1051P-10 - $80.00
* Speed Pro 120 M -Std. - $65.00 (2 sets available)
* Speed Pro 120 M -10 - $60.00
Rod Bearings -
* Sealed Power 2130CP-20 - $60.00 (Set of 8)
* Sealed Power 2130CP-30 - $60.00 (Set of 8)
* Sealed Power 2130CP-30 - Not in original box. Mocked up in rods but never assembled - $50.00 (Set of 8)
* Clevite CB-481 P-20 - $80.00 (Set of 8)
* Clevite CB-481 HN Std. - $90.00 (Set of 8)
Other Odds & Ends-
* Milodon 21530 cam/oil pump drive gear, 4130 chromoly shaft, small block - $100.00 (SALE PENDING)
* Milodon 45225-8 - 1.60” MegaFlow exhaust valves, 21-4N stainless steel, 3/8” stem, 5.000” O.A. length, NEW - $100.00 (SALE PENDING)
* Pioneer PC-780-10 Small block oil pump drive bronze bushing - $15.00 (2 available) (SALE PENDING on both)
* Pioneer OP-72 - standard small block oil pump (M-72) - $40.00 (SALE PENDING)
* Mopar P5249636 crank snout oil slinger, - $15.00 (SALE PENDING)
* Amsoil Engine assembly lube, 4 oz. - $8.00 (SALE PENDING)
All prices + shipping.
I'll find the cheapest rate - First Class, Regional Rate Priority, Priority Flat Rate Boxes or Fed-Ex shipped from Florida 32117
Sorry, no PayPal.
I'll take these if available.
Milodon 21530
Milodon 45225-8
Thanks
I have 2 inquires ahead of you and waiting on a confirmation from the first one. But the valves are available. I'll be in touch. PM box has only 1 spot left.
Hello. What's left for sale? Thanks.
All of the items with (SALE PENDING) have been sold. The 'window" to edit had closed so I couldn't follow up. But most of the rings & bearings are still available. PM for more info or other inquiries.
