68kingcuda
Active Member
Small block mopar edelbrock valve covers new $100
Billet roller timing set &100
two set of 1.5 iron roller rockers and 1 set of rocker arm shafts $300
Race W2 68cc with valves $1200
Indy intake new $400
mopar high volume oil pump new $50
3/8" pick up tube $50
2 moroso oil pan new & used 8 qt $200
4" crankshaft 4340 steel(360) ohio crankshaft $605
ohio crankshaft rod H beam 6.123 new $390
main girdle kit $280
360 block stock $100
Engine plate A body small block $75
comp cam roller cam with cam card new 660 @.50 288/296 CL 109 $200
roller lifter new $280
distributor Bronze Gear for roller
will sell everything for $3800
Will neg on the parts just hit me up
