Small Block Down Flow Radiator
urdustd
River Falls, WI
Anyone know of a source for a small block (upper hose drivers side) 3 core or more copper or an aluminum 2 core radiator? I've check ebay, google search, etc. Someone has to have a source! If not I will probably order a Summit Cross flow....
I'm sure that's a nice piece, but just a bit out of my price league. I would like to keep it under $350...that $143 Summit piece is looking better all the time!
I have a radiator post in the big block section about a summit rad we used in the yellow duster the upper is on the pass side but its a 27x19 2core alum summit rad for a fox body stang and I had tabs welded to it I made but it cools the 440 in it fine with no probs. We took it out a cpl nights ago when it was nice and hammered it a bit to see if it stayed cool and it was fine cooling a 10-1 440 w/stage 6 heads and the 528 mp solid, prf rpm, has a 3500 stall and 3.91s. has a 440 source water pump and no thermostat(has a restrictor).
