small block mopar parts and dodge dart for sale
earthmover
in the tire smoke
nc
1. 1973 dodge dart roller for sale (6cyl car) has the a/c stuff in the truck of car, car needs to have pass/side qter replaced or repaired..when i got car it had a 7 1/4 rearend init..i have a 8 3/4 i will sell with car if someone wants the car and rear..$1000.00 for car and 1200.00 for car and rear..obo (car is complete will not part out sorry)
2.587 heads stock with the red springs and valves (need to be reworked they are stock) $75.00
3.915 heads comp cam springs,locks,and ret. and mild port work $500.00
4.j heads comp cam springs,locks,ret.,and milodon valves, with port work $650.00
5.keith black 107 pistons and stock rods with arp bolts $200.00
6.comp cam 292/501 hyd cam new never been in a motor $75.00
7.comp cam 282sx soild lifter cam 520/540 lift with lifters (few 1/8 mile passes) $175.00
8.x-cal intake single plane $150.00
9.torker 340 intake ports gasket matched $150.00
10.crane cam gold rockers and shaftes $225.00
11.mopar blue valve covers (has a small ding in 1 cover) $75.00
12.elictric water pump motor ,belt,pulley,and mount $40.00
13. small block mopar dist. been locked out $60.00
14.small block mopar headers $50.00
15.small block mopar 727 trans,trans has deep pan,all the good parts inside,and turbo action rev. manual valve body $500.00
16.8 3/4 rearend houseing (a body) $250.00
17.2 radiators 1 out of my 74 cuda and 1 out of my 70 duster $50.00 each
18.a body small bolt patt. axles $75.00
19. mopar right angle oil filter adapter $40.00( think i have 2)
20. set of small block mounts $30.00
21.comp cam small block push rods (few 1/8 mile passes) $50.00
will add some more pics as i take them thanks
pm me here :glasses7:
  • it's NOT ok to contact this poster with services or other commercial interests
may make some trades on big block performance parts..low deck
PostingID: 2675717133
Pm sent for Crane rockers and shaft. You could take some pictures? 1.5 or 1.6 ratio?Thanks
hey buddy im building a 71 scamp and i need the 8 3/4 rear end please tell me you still have it and what state do you live in thanks man
more pics sorry i thought i put all of them on mike:banghead:
still have a few more i have to download .
the small scrap on the rocker is where we 1st started the new motor and it was lose..ran with no problems.
radiators did not leak when took out of the cars...some fins are touched as you can see..1 radiator has had a repair but again di not leak..
motor mounts came off my 318 that was in the duster when i got the car..i good shape i got the 1's for 340 from engine swaps are what ever you call them for 150.00 i think...dumb melol
push rods i got new from comp cams.. about 20 passes on them work great with my soild cam 340..
j heads went 7.40 at 90 in the 1/8 mile with a bad 60' 1.67,,milodon valves ,comp cam springs,locks,ret,and port work......
kb pistons almost new motor was done but ate cams no passes at all,has arp rod bolts and on stock mp rods
mp blue valve covers i used them on my 340 has a small ding in 1 of them but worked good ..(thick gasket) the tape on the covers is to hold the rockers in there wrap in the covers...
3 groove crank pulley and 2 groove water pump pulley..
more pics :blob::blob:
like to sell this stuff so make me a good offer..will not give it a way but dont need it anymore ..going to a big block in a driver instead of the small...open to trades on big block performance stuff...what you got ????thanks mike
10.crane cam gold rockers and shaftes $225.00 (sold)
12.elictric water pump motor ,belt,pulley,and mount $40.00(pending)
21.comp cam small block push rods (few 1/8 mile passes) $50.00(sold)
thanks fabo
interested in the following items:
PM sent!
Today was a long day at work and could not make your turn. Tomorrow at 8 am'll go to the post office to do it. Sorry.
any trades out there big block performance stuff..what you got....:angel9::angel9:
What size valves in the J-heads? What would shipping run on them to Troy Kansas 66087. Thanks Rick
They have 2.02 / 1.60 milodon valves and comp cam spring,locks,ret, the heads has more in them I. Going big block stroker so this stuff need to go that's the reason for the sale. Also putting a big block in the dart if it don't sale. Will check shipping today and shoot you a pm thanks mike
thanks rulogtx got it today will send pm with tracking info..thanks again mike:prayer:
