3404spdDuster
Like the title says i have a few parts from one of my projects i parted out, parts came off my running 360 small block..
PM if interested
Located in Racine,WI
Paypal Verfied, WIll ship with in the 48 States
Items are forsale locally on craigslist so i dont know how long they will last!
Items are all Sold As Is since there used!!
-Edelbrock Aluminum Valve Covers for 273-318-340-360 Powder Coated Blackl Pearl, One also has a lil chuck missing on the lip, Does not leak...90$
-Small Block 273-318-340-360 Edelbrock Preformer Aluminum 4 barrel Intake, No Cracks or stripped threads, Poweder Coated Black Pearl....175$
-Small Block 273-318-340-360 Offenhauser 360° Aluminum 4 barrel Intake, No cracks or stripped threads, Powder Coated Black Pearl...185$
-Mopar 360 Short Block Rebuilt 10:1
My plans changed so i will not be needing this motor.
About the motor:
-78 360 block, casting # 4006830-360-10
-360 Forged Crank, casting # 4027169
-Bored 30 0ver
-Ridge Honed
-New Cam Bearings Installed
-New Freeze plugs
-Dipped and Cleaned
-Keith Black 107's 30 over pistons on stock rods
-Clevite 77 Rod Bearings
-Arp Rod Bolts
-Windage Tray Setup
Also comes with:
-Water Pump housing with new seal
-Comp Cam High Energy Hydraulic Lifters
-Comp Cam High Energy Cam. .450 lift
-Dip Stick+Tube
-Harmonic Balancer
-Oil Pickup Gear
-New Double Roller Timing Chain
-Random Gaskets
Asking 1,000$
-Small Block 727 from 1967, came from a police car or taxi, Unkowen mileage, Unknowen if its good or not, pulled the pan off and was sludgey, So good for a rebuild or build it up!...60$
PM if interested
About the motor:
-Bored 30 0ver
-Ridge Honed
-New Freeze plugs
-Dipped and Cleaned
-Arp Rod Bolts
-Windage Tray Setup
Also comes with:
-Dip Stick+Tube
-Harmonic Balancer
-Oil Pickup Gear
-Random Gaskets
Asking 1,000$
